The shims are now officially ordered along with a couple of extras in the larger sizes because now I’m heading back to work I’ve got access to a surface grinder and a very small 3 jaw chuck to mount on it and hold the shims. I can machine the chuck jaws so they don’t pinch the shims and if I need to modify a couple I can do them with no risk of them going airborne
I’ve given the chromed mudguard bracket 3 coats of acid etch primer and done the same to the somewhat faded plastic cover that goes over the starter motor. They’ll both be getting sprayed with 2K satin black when I do the exhausts and associated clamps.
I’m hoping to get the engine finished when I get a couple of days off but I’m back on 12 days on 2 days off for about 6 weeks so time is the enemy. I’m collecting the wheels on Saturday morning so I’ll fit the new shims and bearings then they’ll go straight in and I’ll bleed the brakes at the same time.
I know I’ll have missed something but it does seem to be getting closer to completion
I should have added that I was talking to a guy on the phone today who rebuilt the top end on his engine a few months ago and his recommendation is to put small centre dot marks on the cam sprockets opposite the high points, set it to the standard timing marks then work back from there to set the valve opening/closing positions with a degree wheel. He said he wasted hours going down the same route as me and since running it on a dyno he now has the best setting for producing power that starts lower in the rev range then tails off where the red line is rather than having a peaky engine which is fuck all use without the close ratio gearbox. He’s going to email me the settings later and I’ll put the cams in my lathe, find the high points and count back on the teeth to set the references. Every tooth is a touch over 10.5 degrees so even a fool like me should be able to work it out
