the twin cam RT oil cooled ,that went from 2010 to 2013 did any have a fuel strip or were they all a float system.and if so what year did they change
Yup, You can only go Strip to float if you have the right ZFE - i think its the High unit (Three types Low - Basic- High) and as PuK says some repining and a session on a GS911 or MotoscanIIRC the pinouts are different between the ZFE with fuel strip and float, I think you need to do a bit of pin swapping to convert from strip to float rather than just plug and play, so going back the other way would presumably need changes also?
Not that I know of, I wouldn't worry too much about it as long as your fuel gauge works. I've had my 2005RT 7-8 years and the fuel strip still works fine.Is there any way I can tell visually whether my 2010 bike has the strip or the float?
Yes I think there is, the earlier 2010 had the “old” style front forks and the fuel strip. They went through an update in late 2010, front forks changed and the fuel strip for the float type. Hope this helps.Is there any way I can tell visually whether my 2010 bike has the strip or the float?
That's right... my neighbour's 2010 plate RT has the old style forks & definitely has a fuel strip. After we replaced the complete wiring loom & ZFE module last year due to a fire, we can't find the correct ZFE version, one off the later MU 2010 bike works in every way apart from the fuel gauge, this is probably because it's looking for a float type gauge.Yes I think there is, the earlier 2010 had the “old” style front forks and the fuel strip. They went through an update in late 2010, front forks changed and the fuel strip for the float type. Hope this helps.
