Before you put the airbox in, you need to put the cross over balancing petrol pipe under it.
But you knew that.
Mofo. Do now!
But you knew that.
Sorry
Not at all - saves me finding out much later …
I'm still waiting for the picture of it in place. Come on!!!
... Good spot though! Did you like the head gasket …
But you knew that.
I have the gearbox breathers in stock they are an HPN item, also your head nuts are upsidedown
After all the time and effort why not get someone to make you a decent speedo blanking plug
This is what i made for mine...It even lets the gearbox breath like the original to take the pressure off the oil seals
with a pipe that goes up under the tank
After what I sacrificed for you.
Are your rocker shafts in the right way up? It's difficult to see the usual dimple on the end.
