Need to remove the rear shock, snapped a T50 trying to remove bottom bolt. I am aware now I need to warm it up first but before I try again I want to make sure I have the correct size T bit.
Thanks Panos.Both rear shocks (top and bottom) are M12 so a T55 torx is needed
I did find out when I removed mine putting back together, that they are different lengths, obvious I know but always worth checking and checking again.
In order to get a bit of heat in to the bolts and free up the threadlock, I chose to heat the bit with a blowlamp and then leave it in place to pass the heat on. Twice over, top was easy and bottom a little harder.
Having just changed my rear shock 2 days ago, I don't think your application of heat on the bolt head will do any good.
It's a M12 Fillister head bolt that is 75mm long, that goes thru an incredible heat sink on the Paralever, then the lower bushing of the shock which is 38mm across, then into about 15mm of thread engagement on the other side of the Paralever.
Using a heat gun directly on the RH side, bottom of the Paralever, where the thread locker is on the threads is the only place where application of heat will do any real good.
As with any application of heat on painted parts on these bikes, monitor the area temp so you don't exceed 100 deg C.
