Good news, of a sort.
In the dark this evening, I connected a brand new Garmin Zumo XT to my bike, mounting it onto a bespoke mount on the steering column. I can now replicate exactly what Phil saw.
When the XT is displaying satellite lock on it screen, even in central London, with an obscured view of the sky, it can lock onto several satellites and display the bike’s potion within 10 feet. Good enough.
If I turn the ignition on, but not start the engine, the XT loses its satellite lock steadily and the positional accuracy drops to 100 feet.
If I screen the XT with my hand cupping the rear or bottom of the device, the satellite lock returns to an accuracy of 10 feet. If I remove my hand, the accuracy drops to 100 feet.
If I turn the ignition off, the XT is stable again, locked to its satellites.
If I move the XT rearwards, away from the front of the bike, the accuracy returns to 10 feet. If I move it forwards again, the accuracy deteriorates once more to 100 feet.
I have spoken to my daughter’s boyfriend, who has an automotive electrical mechanical engineering degree and works at Ford’s engineering research establishment at Dunton, Essex. He had several ideas on why only my and Phil’s bikes are doing what they are doing:
Answers / guesses, without him seeing the bikes are:
A. That they are displaying all the symptoms of RF leakage from ‘something’. It’s a classic problem, he sees a lot of it. It’s sometimes a bitch to trace on a car, van or lorry, especially when you work on development vehicles as he does.
B. He doesn’t think it’s the transponder for the keyless ride, as that is “The ‘wrong type’ of RF”.
C. Why does it apparently ‘only’ affect my and Phil’s bike? Good question, he said….
i. Perhaps some people do not ever use the cubbyhole or even the Connected app, so they would never know.
ii. Perhaps some people never put the phone in the cubbyhole but instead put it in their pocket. They would never experience it.
ii. Perhaps people who mount a separate gps unit on say the mirror stem or even by the clutch or brake reservoirs (or anywhere a bit distant from the RF source) might never experience it or the drip off would be milder.
iii. Maybe (and he liked this one, as they have seen it at Ford’s) there is an optional extra on Phil’s and my bike, which is not present on other bikes. It is possible that one optional extra is causing the problem. He said, try the radio unit, as that is an optional extra on my bike. Tomorrow I will pull the 15 amp fuse out of the radio unit, to see if the satellite lock comes back.
He also said, “Pull anything that has a fuse” as that might isolate the problem. So I’ll do that too, with the aid of the often ignored owner’s manual:
Sadly, I can’t pull the 10 amp fuse as that will kill the ignition switch, which needs to be on to create the RF. To pull the fuse and keep the ignition live, would mean me taking half the front of the bike apart, which will be a nice job for BMW.
He added, the TFT screen itself can radiate as well, as can just about anything electrical. The lights are sometimes a good bet, too.
iv. Some faulty or poorly screened module “somewhere”…. Good luck!
v. Anything dealer fitted, as opposed to factory fit, is a common cause…… They often start there!
Watch this space.
