Connect it to an inverter.
So connect to inverter to go from 12 to 220? Then plug in a battery charger to give 12 volts? Why not loose the charger and inverter? JJH
Has anyone used a portable power station (Jackery type thing) to operate a mains powered battery charger?
You seem to have missed the OP’s declaration that he wants to use a portable power station (I had to Google that up, to discover what it is) for two separate purposes:
1. To keep his motorbike battery charged, which (remarkably perhaps) is flattening itself in two weeks
2. To use whilst camping
One stone, two dead birds.
The power stored in a battery is measured in Watt Hours, not Amp Hours (Ah at what voltage?, meaningless statement)
If you can live without the big power station for camping, then why not just buy a small jump start pack like the ones from Antigravity, NOCO or similar and just take it with you when you need to start the bike.
If the bike starts, all is good, but if not just use the jump pack...
If the bike doesn't start, battery most probably packed in because it sat in a discharged status.
He'll be jump starting the bike and changing batteries continuously.
But that's lithium.
I think OP has traditional lead acid battery.
But I'd be checking why is goes dead in 2 weeks first!
A battery that has been left discharged that much will have suffered the effects of sulfation.
Unless you recharge it immediately, it's damaged. And has a way shorter life.
100% agree.
I have a CTEK 5.0. They are extremely good. They just don't perform miracles
It’s been a while can’t remember now. Probably an old model.What kind of solar charging system were you using?
Just to report my experience.
At some point I had 2 Optimate solars and three bikes. I did build myself another solar charger with leftover parts I had from the main solar setup (the one that charges the deep cycles batteries I use for lights, camera, and tools in the garage) but, same as you it didn't really work. No idea why.
Bike was the DRZ. Small battery, died as well.
At some point I bought another Optimate Solar and hook that one up too. Been ok since.
They might be slightly more efficient – no idea.
