Portable power station
vRSG60
Barrowford Lancastershire
Has anyone used a portable power station (Jackery type thing) to operate a mains powered battery charger?
My garage is a mile from my house and has no mains power. In winter the GS battery lasts about 2 weeks, I blame the tracker.
I’d be looking at using the power station to operate a typical mains powered battery charger so I don’t need to keep taking the battery off the bike and bringing it home to charge should I need to.
That would work but if you leave the portable power station connected to your bike for an extended period, it too will go flat
Yes but my thought being, I use the power station to run the battery charger to fully charge the battery then leave it 2 weeks and do it again with a fully charged power station.
Next question would be what size power station to charge a 12V 200A 12Ah battery.
The power station would also be used for camping.
I’ve tried solar panels and got Jack shit out of them in winter!
Ah, more than one purpose. That makes more sense.
A basic solar panel probably won’t do that much. Link it to the proper Optimate gear and it will work wonders.
12v x 12Ah = 144Watt Hours
Assume 50% efficiency
Means you'll need a power station with a minimum battery capacity of 288 Watt Hours
I've been eyeing up a Jackery for weeks now, crazy price yet on marketplace there are loads cheap which makes me wonder about them being genuine.
Price new is around a £1 per ah = 500ah = £500.
The power stored in a battery is measured in Watt Hours, not Amp Hours (Ah at what voltage?, meaningless statement)
Am I stupid? Just get a big car battery and connect it with jump leads. Even at 50% efficiency’s it must give you 6 weeks? And then charge it up. Or am I missing something? JJH
So the cheapest 240Wh would do. Can’t imagine 50% efficient in this day and age.
If your bike battery (144Wh) is flat, it takes more than that 144Wh to charge it up (battery gets warm for example)
Your 240Wh power sation only achieves / produces that with optimum discharge conditions (when it's new, temperature, power draw etc)
In addition, add the conversion losses, power station battery volts to mains volts, mains volts back to DC to charge your bike battery
50% was a guesstimate but probably not far out
If it were me, I would fit a charger lead directly to the battery therefore bypassing all the bike's electronics and connect this via another appropriately fused lead to a fairly large car battery.
This will obviously have a much larger capacity than the bike battery and maintain the alarm/tracker etc for much longer.
I would then monitor the car/external battery to determine how long it takes before becoming discharged and then take it back to the house before this time to charge it.
2 weeks is a tad short current draw should be minimal
Is the battery actually in good condition ?
A leisure battery for a boat / caravan would be a good power source its made for long slow discharge
and considerably cheaper than the powerstation thing :aidan
If it were me, I would fit a charger….
You seem to have missed the OP’s declaration that he wants to use a portable power station (I had to Google that up, to discover what it is) for two separate purposes:
1. To keep his motorbike battery charged, which (remarkably perhaps) is flattening itself in two weeks
2. To use whilst camping
One stone, two dead birds.
there seems to be a trend forming in recent posts of some trackers draining batteries in a couple of weeks - most likely where the tracker has to keep boosting power to talk to base due to a weak cell phone signal.
That's what I did when I had a garage without mains power. Though it doesn't have the multiple power outlets the portable power station has, but it's way cheaper.
